? about connecting an int amp to my receiver
Hi folks!
My receiver has a multi room out (RCA connection) and I got a vintage Marantz integrated amplifier off eBay (no manual) that I want to connect to the system to fire some power hungry 4-ohm vintage speakers in another room. On the back of the integrated amp, there is a set of 4 RCA connections that have two U-shaped brass pins connecting them all together. There's two "Pre-out" plugs and two "Main in" plugs. The U-shaped connectors go from pre-out L to main in L and pre-out R to main in R.
I was thinking I'm supposed to pull the pins out and connect the RCA cable from my receiver out going into the "main in" plugs, but thought I ought to check first. Is that right?
Thanks!
Back to top
View user's profile
