Results 1 to 4 of 4
    Aug 2004
    70's Yamaha receiver & CD player compatable?
    I know the receiver has no inputs for a CD player, Can I hook up to the phono inputs? how will it sound?
    This is just a basement system, not my mail unit. just need a CD player to jam along with my guitar playing.
    May 2003
    NY
    Do Not Use The Phono Inputs!
    Quote Originally Posted by docrock55
    For anything but a phonograph. Use the Tape inputs instead. It should work just fine.
    Audio;
    Ming Da MC34-AB 75wpc
    PS Audio 4.5 preamp,
    Suspended markw's Avatar
    If you have no other choice then the tape inputs will work but, you also can use an "Aux" input as well.
    You''ll overdrive the bejeezus outta that poor phono input and it'll sound like H-E-double hockeysticks. ...that's NOT a good thing, as Martha would say.
    Aug 2004
    Thanks for the info guys.
