Advice on DAC/Sound card upgrade...
Hey all!
I have an ASUS STX card which I am happy with. It has, as far as I know, some pretty good specs. My question is; what would be a "next step" upgrade? I would be willing to spend upwards of $1k. However, the specs of the ASUS seem to best DACS which cost many times the ASUS. For example, the ASUS has a signal to noise ration of 124 dB. I realize that there are other factors which weigh into converting digital signals to analog. What do you guys suggest?
Thanks for the advice!
Jason
ASUS STX Specifications
Output Signal-to-Noise Ratio (A-Weighted): 124dB for Front-out,117dB for Headphone-out (600ohms) dB
Input Signal-to-Noise Ratio (A-Weighted):118 dB
Output THD+N at 1kHz:0.0003% (-110dB) for Front-out, 0.001% (-100dB) for eadphone-out
Input THD+N at 1kHz:0.0002% (-113dB) for Line-in
Frequency Response (-3dB, 24-bit/192kHz input):<10Hz to 90KHz
Output/Input Full-Scale Voltage 2 Vrms (5.65 Vp-p)
Bus Compatibility PCI Express:
-PCI Express Rev. specification compatible
-Compatible with X1, X4, X8, X16 PCI Express slots
Main Chipset High Fidelity Headphone Amplifier:
Texas Instruments 6120A2*1 (120dB SNR, 100dB THD+N @ Vcc±12V, RL=600Ω, 1kHz) Audio Processor:
ASUS AV100 High-Definition Sound Processor (Max. 192KHz/24bit)
24-bit D-A Converter of Digital Sources:
Texas Instruments PCM1792A*1 for Front-Out (127dB SNR, Max. 192kHz/24bit)
24-bit A-D Converter for Analog Inputs:
Cirrus-Logic CS5381* 1 (120dB SNR, Max. 192kHz/24bit)
Sample Rate and Resolution Analog Playback Sample Rate and Resolution:
44.1K/48K/96K/192KHz @ 16/24bit
Analog Recording Sample Rate and Resolution:
S/PDIF Digital Output:
44.1K/48K/96K/192KHz @ 16/24bit, Dolby Digital
ASIO 2.0 Driver Support:
Supports 44.1K/48K/96K/192KHz @16/24bit with very low latency
