Results 1 to 9 of 9
    SuperPoser Rock789's Avatar
    Feb 2005
    Ohio
    1-BIT DLC (Direct Linear Conversion)
    I've got an old pioneer cd changer which has a 1-BIT DLC DAC (I believe)
    it's a Pioneer PD-F906...
    I am running this into a B&K PT3 series II pre, Anthem PVA 2 amp, and running Von Schweikert VR1...
    I figure the Digital Analog convertor is the weak link, and will be shortly trying a denon 20bit DAC, but would you guys suggest a much better DAC or am I going in the wrong direction with this?
    also, any info on upgrading the Pioneer CD changer's output?
    thanks,
    Mike
    HT: Anthem AVM 50 / PVA-7; Focal JM Lab 4x Chorus 716 S, CC 700 S, 2x Chorus 706S; 2x 12s - Homebuilt Sub
    2CH: B&K PT3 s2, Anthem PVA-2, VonSchweikert VR-1
    Computer: Denon AVR 2805, Old Tecnic & Optimus Speakers
    2004 KTM 200 SX
    2003 Spyder
    2002 Single Cab, 3" cornfed lift, 34"LTB & 31" AT's
    ONLINE PHOTO ALBUM
    Jul 2006
    1 bit?
    are you sure about that?
    at one bit you'll be able to hear beeps,
    try looking out for a totally new cd player...
    Life is music!
    Mcintosh MA6400 Integrated
    Double Advent speakers
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-103 in midas body
    *Denon DL-304
    *Lehmann audio black cube SE
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Sonic link Black earth IC's
    Siltech MXT New york IC's
    Kimber 4VS speakercable
    Furutech powercord and plugs.
    I'm a happy 20 year old...
    Feb 2005
    Ohio
    1 bit?
    the front says "1-BIT DLC"... I googled this and it says it was a type of digital to analog converter, but I am not sure how this works...
    the changer does have optical out, which is what I am looking to use in the future...
    2004 KTM 200 SX
    2003 Spyder
    ONLINE PHOTO ALBUM
    Jul 2006
    maybe better indeed, then the signal will be converted by the receiver's dac, it should give better sound...
    Life is music!
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-304
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Same for my old Technics CPD
    Quote Originally Posted by Rock789
    thanks,
    Mike
    I have an old Technics player, circa 1991, that claims to have a 1 bit DAC. I once read a explaination of what that meant but I didn't really understand the details, and don't remember them now in any case.
    The old Technics was a huge improvement over the Yamaha I own previously, some model circa 1985, but today it sounds grainy and lacking in detail.
    Crackhead Extraordinaire Registered Member Dusty Chalk's Avatar
    below the noise floor
    1-bit DACs were all the rage in what seems like a lifetime ago, but at this point, it's ancient technology. Pretty much anything, even the Entech Number-Cruncher (for $50 at various online sites), will be better.
    Eschew fascism.
    Truth Will Out.
    you guys are crackheads.
    I remain,
    Peter aka Dusty Chalk
    Jul 2006
    yeah, today it's all 24 bit 96 khz dac's, mucho better, more detail, more clarity, better buy one of these ($200 and up)
    Life is music!
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-304
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Margate, Florida
    I think the one bit deal started with Harmon Kardon. I have one bit dlc in my cld-m90(Pioneer) laser disc player. I could not tell you how it worked but it supposed to be a better scheme to give better audio in the digital domain with CDs. If you have an optical output on your player with a receiver with optical inputs,just run it into your receiver.
    Feb 2005
    Ohio
    I have used this changer for a couple years with my denon receiver (using the optical out of the cd changer)...
    the cd changer has been moved to my bedroom system with a B&K PT3 s2, which does not have an optical input.
    if I do any upgrade here, it will be a DAC, and I do have a denon 20bit dac on the way but it has not yet arrived...
    if it is worth it, I will spend the money on a good 24bit dac sometime in the future, but not sure if it will be a huge difference?
    2004 KTM 200 SX
    2003 Spyder
    ONLINE PHOTO ALBUM
