What cables will I need for the following HTS?
I'm planning on finally taking the plunge into HD. I've done some research, and these are the components that I'm planning to buy for my 12 ft. x 12 ft. living room:
TV: Samsung LN32B650
DVD: Samsung BD-P3600
AVR: Onkyo TX-SR606B
Speakers/Subwoofer: Energy 5.1 Take Classic
If you see any issues with the above selections, please feel free to voice them.
Now I need to figure out the right cables to purchase to connect all of these things so that I don't unnecessarily downgrade the experience by buying the wrong kind.
For HDMI cables, the Mediabridge - 6ft Ultra-High Speed HDMI Cable - 120 Hz - Version 1.3 Category 2 seems to be popular on Amazon. How many do I need? Would you recommend an alternative?
I believe that I also need speaker cable and a subwoofer cable, as the Energy system comes with neither. Is there a specific brand/gauge of speaker cable and of a subwoofer cable that you would recommend that won't wind up costing me multiple hundreds of dollars? I want realistic sound, but I also only have a 144 sq ft room. :-)
Any advice you can offer is greatly appreciated.
Thanks,
Mike
Re: What cables will I need...?
Thanks for the link. I'll check it out. Yes, I will have a cable box as well, so it sounds like I'll need 3 HDMI cables.
