Subwoofer connection using 18 guage speaker wire
Hello All,
I routed 14 gauge speaker wire in my wall and ceiling to connect my receiver to a Klipsch RW-12d. I was told by a local hi-fi shop that this (speaker wire) would be acceptable as I only needed to carry the "single". How do I finish the connection with RCA connectors? Please advise.Thank you!!!
Sounds like your mind is made up.
Well then, since RCA plugs aren't made to go on to that cable. you're gonna have to jury-rig them onto the ends.
Just make sure that wire you use for the center pin on one end is the same one you use on the other end.
Once you get that worked out, solder the RCA plugs onto the ends of the wire. Again, since they aren't made for this, it may be messy.
Good luck, and I hope you don't pick up any noise by not using shielded cable.
PS, Your store did you no favors here. They should have known better. Are you sure you didn't cajole them into "approving" this?
