subwoofer cable
right now my sub is hooked up with what the sales guy gave me for free i just noticed it was a video cable. i just would like to know if i should get a subwoofer cable and what i should get(best buy is like less than a block away so if i could get it there that would be great, also i have a friend that works there that will buy cables for me at discount) thanks for any help.
found a post about it looks like the video cable is ok to use
as long as it is decently thick it will sound the same as a sub cable,
Yep, it is a very good cable to use. Usually the sub cable is a renamed video cable with a higher price:)
