Listen to it to see if you hear a difference.
Originally Posted by alt4
I use the one in my pre/pro...from reading the specs, it's def. better!
Specs don't tell you what your ear will hear. Only listening will give you what sounds best to you. I've found coax sounds more open for the money over optical. Otherwise you might want to use RCA cables on the analog side over optical, but YOU should be the judge of what sounds best, not the specs. Do an A-B comparison and set it up to please you.
