Speaker wire for brighter sound?
I'd like to upgrade my monster 12awg speaker wire to something that would sound bright and detailed, anyone know of any good affordable bang for the buck speaker wire?
For a short run, I doubt you'll hear a hugely obvious difference in the frequency response by changing to a different speaker cable. If you want a brighter and more detailed sound, the simpler solution would be use different speakers or remove anything in your room that might excessively absorb the high frequency sounds. Alternately, you could simply turn up the treble tone control (if available).
Try a EQ works for me.Try one that is stereo and as feedback detection.
well my room is small and I noticed that I have a lot of furniture in the room and the speakers are placed next to some furniture so there is definetely more bass...
Are you using a subwoofer in your room? Small rooms have all kinds of issues with standing wave formation, which can create boomy peaks as well as low frequency cancellations. An overly boomy sounding bass can drown out the highs and midrange by forcing you to adjust your master volume level to account for the boomy low frequency peaks. If you can, you should try repositioning the speakers. With a two-channel system, that entails pulling them out a few feet from the front wall if you have enough space.
Try some Cryo-Max 2 cable from www.cryo-parts.com The word is getting around about this cable ...they can not keep up with all the orders for this stuff. I think they might make some more of this cable next month some time.......
Everything I've heard/read says that Cryo-Crap cable is overpriced junk. I'd avoid.
I agree, you shouldn't look for speaker wire which enhances anything (highs or lows). The only way wire can add anything to the listening experience is by changing the inductance, capaictance, or resistance of the speakers xover thus changing what the designer intended. The wire should be transparent. As stated before, placement and removing materials which are absorbing the high frequencies (making the room more live) will have more effect than changing the cables.
Make a comparison of the specs - selecting speaker wire with the lowest possible capacitance will allow more high freqs to fight their way down the wire and make it to the speaker.
As mentioned earlier, short runs won't make a night & day difference.
Two questions.
1. How old is the wire? Basic Monster is notorious for a greenish black oxidation that kills detail. Is the copper still shiny looking?
2. What is the rest of your system? Perhaps the solution lies elsewhere.
FWIW, I prefer cables that seem dark at first blush. All sorts of RF nasties end up adding a brighter haze to many cables.
Keep in mind that different speaker wires will sound different with each system setup; what will agree with one person's ears may not agree with another. Also, if you're looking to get more detail and punch out of your sound system, you might consider investing in a high-quality power cord if your receiver / amplifier supports detachable power cords.
Personally, I've heard a lot of speaker cables over the last couple of years, and one of the best by far, in my opinion, is my current cable, the AudioQuest Bedrock. At one point, this was one of AudioQuest's best cables and came at a hefty price (here in Canada, about $22 per foot + terminations), and can be had on eBay for about $175 for a 10 foot pair. I don't believe AudioQuest offers it anymore, so I think it would be a good investment. I know that once I upgraded to the Bedrock, and also upgraded my power cord on my Yammie (I'm using a Merlin Black Widow), my speakers REALLY came to life... much tighter lows, smoother mids and brighter highs.
Another reason why I suggest the Bedrock as a great all around cable is because I know many audiophiles personally who have $50,000+ audio systems and swear by it. You would think that at the higher end, people would use silver cables, but it's a fairly well known fact that, while silver cable is "faster", it doesn't quite have copper's density and ability to produce as much bass, and as far as copper cables go, you can't go wrong with Bedrock.
But, don't take my word for it... the best thing to do is go into a store which carries multiple cable lines and audition them, and see what your ears like most... experiment, experiment, experiment :)
Might I also add BTW, that I really did my homework on the Bedrock cable prior to buying it, and it is extremely well reviewed. I think you'll find that if you do some research on it, people who have it, tend to like it a lot, as it uses thick gauge, solid copper, and also tends to sound very neutral once broken in. One thing is for sure.... it will beat the snot out of any Monster cable, guaranteed.
Give these a try....they lack character.
http://www.anticables.com/
Point blank, changing wires ain't gonna do it.
Honest audiophiles say that changes due to wires, if any, are very, very subtle,
You either need to reposition the speakers or replace 'em with some that are more to your liking.
Of course, it's your money ...and they want it.
Mark... it depends on the price point we're talking about here, changes due to wires can have a very profound impact. In this instance, going from standard Monster 12 AWG strand cable to a multiple solid core cable say, such as an AudioQuest Slate or Bedrock, will make a HUGE difference. Braided strand cable, like generic Monster, uses low purity copper, and this affects sound quality greatly, as lower purity copper oxidizes and wears out faster, not to mention that by the time the signal hits the speaker, it's heavily degraded. Cable shielding is also a big factor in sound quality, as the shielding helps to limit the interference coming from "dirty" signals. Generic cable uses either cheap plastic or teflon coating, and that's it, and neither really has any interference absorbing qualities. Braided strand cable, IMHO, also doesn't have the density necessary to carry bass signals like solid copper. If you think that cable changes don't make much of a difference, I suggest you take a generic strand copper wire and compare it to multi-wire solid core cable and you'll see the difference it makes. If you can't tell that there's a huge difference, then something isn't right.
On the other hand, the difference is indeed subtle when you're comparing high end cable to high end cable. For comparison's sake, let's take said Slate / Bedrock cable and compare it to a higher end AQ cable, like Mont Blanc. So-called audiophile experts will say that silver cable is better than copper, but this isn't necessarily true. Yes, silver is indeed faster, but it also isn't very good for lows, because it doesn't have the density of copper. Look at the huge price difference between the Slate and the Mont Blanc; it's about $1,000 difference for a 10ft pair. You're paying for two things with Mont Blanc over Slate; silver vs. copper, and the DBS technology on the Mont Blanc. DBS doesn't do anything except maintain the cable in a constant "broken-in" state, so sonically it's a moot point. As for the fact that it's silver, yes, you might notice better speed from the Mont Blanc, but quality will not be much, if at all better than Slate / Bedrock.
One more point to consider is that your best component is only as good as your weakest link... if you have a great amplifier but crap cable, or vice versa, you won't be realizing either's full potential... you have to find a balance of what works and sounds good in the right configuration, and with all that's available, that's a hard thing to do. Which is why I also said, further up, that investing in a good power cord and power conditioner is always a good idea. It's all about balance, not necessarily the need to go overboard.
Bottom line, your point is valid to a certain degree, it all just depends on the level you're comparing cables at... but if you're comparing Future Shop's crappiest to audiophile grade cable, the difference is like night and day, no question about it. Again though, listen not to the experts, find something your ears like and stick to it... if you like it, who cares about price.
Point blank, bullshiite.
Some guy here did a fairly exhaustive test between cheapo $15 12 gauge and $1,000 fancy dancy cables. He said he shortened the cheap cables so, for the sake of argument, let's call them $10 cables.
That's about a ratio of 100:1 price differential. For that price difference I would expect to hear a "marked" difference. About four times out of 20 or so he couldn't telll any difference at all. So much for a marked difference based on price, eh?
But hey, it's his money. If he wants to play this game, more power to him. As with all gambling, I hope he can afford to lose.
Some guy here did a fairly exhaustive test between cheapo $15 12 guage and $1,000 fancy dancy cables. He said he shortened the cheap cables so, for the sake of argument, let's call them $10 cables.
That's about a ratio of 100:1 price differential. for that price difference I would expect to hear a "marked" difference. About four times out of 20 or so he couldn't telll any difference. So much for a marked difference based on price, eh?
Well, the whole idea with using better cable is not only to get better signal transfer, but to hear the minor details which aren't always apparent using an inferior cable. There is, though, a price point at which you get diminishing returns; eventually, no matter how much money you spend on cable, there will be a limit as to how much improvement there is.
It's generally said that your budget for speaker cables should never exceed more than 10 - 20% of the cost of your speakers, again keeping the diminishing returns idea in mind. As I said, there's no need to go crazy, and ultimately, only those with very finely tuned ears will ever tell the true difference with lower and higher grade cable. For the casual user, it's not necessary, but if you can afford decent cable, especially when you get it at a super cheap price like I did, you might as well go for it, as you can use them with any speakers you'll ever own.
I'm not disagreeing with you, only that physics need to be taken into account and to understand why some cable really is better than others.
I think that its impossible to justify cables or say 10 or so percent of the speaker etc...
If it works for you then great, personally i heard the Nordost Valhalla in a personal system for a few hrs and my jaw hit the floor and if i have a couple of grand i will buy that cable. My cables arent too much in my system but i am a believe in solid core cables and the best speaker cable i know is the Magnans which i will eventually buy.
Physics notwithstanding, ...
...once one reaches a level of satisfaction with their system and they then wish to pursue the dimininishing benefits of more expensive cables, fine.
But, to expect cables to alter a systems overall sound balance in such a manner as this person desires is a fool's errand and to encourage such an expenditure is a cruel hoax. Expensive tires and wheels won't change a Hyundai into a BMW.
He must explore first speaker positioning and their relationship to the furnishings in the room. Then, should that fail, the speakers themselve should be replaced with ones more suited to his tastes.
He must explore first speaker positioning and their relationship to the furnishings in the room. Then, should that fail, the speakers themselve should be replaced with ones more suitedto histastes.
You hit the nail on the head!
Well said, you're absolutely right, and as I keep going back to, it's all about what makes you happy. I wouldn't encourage the purchase of expensive cable unless you get it at a really good price, because that cable could be used on even the best of setups. I consider my own example, in how I got a $700 pair of AQ Bedrock cable for under $200, and I think it was worth it, because to me, they made a drastic improvement in the way my system sounded, and I don't think I'd ever buy another speaker cable.
I'm not trying to say that cables necessarily make or break a system, only that a cable properly matched to a particular setup will make a good setup better. When going from generic braided cable to solid core cable, think of it as going from a 3 Series BMW to an M3; it's tweaking what's good about the car for the best possible performance. For the casual listener, the generic cable may very well suffice, but for those who must absolutely squeeze every last ounce of detail from their system, a good cable will help accomplish that. There's no need to go out and buy Nordost Valhalla or Transparent Opus MM cables or anything like that, again going with what I said about diminishing returns; the price difference between a decent AQ cable and Valhallas or Opuses is tens of thousands of dollars, and it's at that point that you wouldn't notice much of a difference to justify the price tag. But let's face it, there's a reason why generic cable costs about $50 per 100 feet as opposed to a good solid core cable which sells for $500 per 10ft pair. While the untrained ear may not be able to notice much of a difference, the fine-tuned ear will be able to hear the distortion and imperfections of the low grade cable, especially on a good pair of speakers.
Consider this... if you had a pair of elite level speakers, say Dynaudio Temptations, would you use the Radio Shack cable? Are you trying to say that room acoustics would give you the maximum possible performance from such wicked speakers using generic cable? And having great speakers like these, if room acoustics don't solve your problem, would you replace these speakers with ones more suited to your taste??? I sincerely doubt it. You don't need to buy insanely expensive cable either, only one good enough to bring out most of the detail of the speakers. And as I said before, your best component is only as good as your weakest link; you have to find a balance of equipment and interconnects which work optimally with each other, and this is something that can only be learned through experimentation and experience.
Above all else, I'm just trying to get to the bottom line about your original comment, how cable makes a marginal difference; I never once disagreed with you, only tried to say that from the generic stuff to a decent audiophile grade cable, there IS a very noticeable difference, and many things, like room acoustics, clean power and your speakers and source, all play a part in how your system sounds. It's all about finding the perfect balance, and as long as you're happy with your setup regardless, that's all that counts.
I'm not trying to say that cables necessarily make or break a system, only that a cable properly matched to a particular setup will make a good setup better... While the untrained ear may not be able to notice much of a difference, the fine-tuned ear will be able to hear the distortion and imperfections of the low grade cable, especially on a good pair of speakers.
I'm in your court overall, but returning to the original question - I wouldn't say that getting better cables will make a system "brighter".
Are you kidding me? Speaker wire to improve sound that much? Now I think I've heard everything. I understand you shouldn't have some el cheapo 18+ gauge speaker wire, but come on. If you have money to blow, more power to ya!
I have speaker wire that costs $25/ft and it makes my TV picture much brighter- you guys should try it out- please send a check made payable to Eric Z at...
On a serious note, if the speaker wire is damaged or a high gauge, then I would replace it, but the 12 gauge is more than enough to pass the correct info from your receiver to the speakers in an efficient manner.
Perhaps you meant to respond to the Greekguy post.
Agreed
I use and endorse high definition cables but they are not to place to start when attempting to change a system's overall tonal balance. They are the final topping on a system that is already properly balanced.
Speaker positioning or room acoustics will go much further to making a system brighter than cables will... or should!
musicoverall - this is what I've been trying to say all along, but it seems that very few understand what I'm trying to say. Everything has to be balanced overall, and even without taking room acoustics into consideration, going from braided 12 gauge to solid core cable will certainly make a difference. Refer back to my point about speaker cable upgrades being the equivalent of taking a BMW 3 Series and making it an M3 - it's taking what's already good and tweaking it to make it better.
The root I'm trying to get at is, what started the initial debate about all this was that cable upgrades would have little to no impact on sound - depending on just what kind of an upgrade you're making, this may or may not be true. Going from Future Shop's crappiest to, say, AQ Slate, will have a much bigger impact than going from Slate to Nordost Valhalla; in the latter case, diminishing returns. You also have to take into account that some cable will sound better with certain amp / speaker combos than others, and the only real way to tell is through experimentation. Saying that cable upgrades may have little to no impact is like saying that twin turbo in a car may have little to no difference over single turbo... depending on the engine of the car and how much extra horsepower it gets, it may or may not make a big difference, and it's the same for audio, it's contingent on what kind of amp and speakers you've got. The question is how much of an improvement and at what price is one willing to accept.
The only thing I don't agree with markw on is when speaker placement doesn't accomplish what you're out to accomplish, buy new speakers... if you have Dynaudio Temptations hooked up to crap cables, and room acoustics don't solve your problem, what do you do, go buy Evidence Masters??? No, you buy better cables.
This point can be debated until we all turn blue in the face, and there's tons of things one can do to improve overall sound, whether it be cable upgrades, power upgrades, speaker placement, new amplifier, putting your speakers on spikes or whatever else. What it comes down to is that the average person doesn't have the time or money to investigate all the possibilities, so whether cable upgrades should be considered as a starting point or not all depends on the type of cable and equipment and whether or not the speakers are already in their ideal placement. Bottom line, if you've readily got the money and can score good cables at a bargain price, it's certainly not going to hurt. When you then ensure that your setup is balanced and all things, such as room acoustics have been accounted for, and you can't squeeze anything further out of your system, it's then you invest in upgrades.
