Power cables??
Printable View
  • 03-31-2010, 09:00 PM
    Mr Peabody
    Yeah, but Ajani I would use the orange ones. You know construction cones are orange.
  • 03-31-2010, 09:18 PM
    atomicAdam
    Originally Posted by Mr Peabody
    A101, I have not upgraded the Quintet power cord. I figured it's a conditioner why would it need an upgraded cord. PSA suggests it but I thought they were just trying to sell another cord. I will give it a try.
    I've run the Quintet I am reviewing with the Granite Audio #560 and it made a slight noticeable difference with the AVA gear I have, which comes with power cords built in. HAHA! beat that Frank. Nah, just playing, just wanted to see if I could hear a difference. And yes, I could. The bass beefed up, beats were a bit punchier and I think there was a bit more detail, but I can't remember. I am for sure certain that the bass improved though.
    So to recap - that is - wall socket -> GA#560 -> PSAudio Quintet -> AVA pre & amp which have built in cords that are very thin.
  • 03-31-2010, 10:34 PM
    audio101
    The trickle down effect is fantastic, there is not really much differnce from the PC's after you put your best at the conditioner, what recepticals do you use? I changed my 6.95 home depots out for the Power port premier and heard lower noise and more sound stage dept and what seems to be effort less dynamics. Video is a whloe story to it self, still cant get over the picture qaulity.:eek6:
  • 04-01-2010, 04:01 AM
    poppachubby
    I'm surprised the AVA gear has cords hard wired on.
  • 04-01-2010, 04:56 AM
    Mr Peabody
    I do intend to put a power cord with the Quintet soon. Those Power Ports I need worse. Time to get an order together.
  • 04-01-2010, 09:46 AM
    Ajani
    Good point, the orange ones would likely make better power cords, while the white ones are best for speaker cables and interconnects...
  • 04-01-2010, 10:28 AM
    atomicAdam
    Yeah I heard similar good things about the power port premier. Those things r only $100, right? Might be a great investment.
  • 04-01-2010, 10:30 AM
    atomicAdam
    Yes, so was I.
  • 04-01-2010, 11:25 AM
    audio101
    Got mine at music direct they let me have it for 84.00, just ask they may give you a discount, or mabe it was because I ordered the Quintet and Soloist Premier along with it overall I saved 10% on everything.The construction is similar to the well regarded R-1 without the high price tag and better lows from what I hear. Face off is needed between the two.
