need help on speaker cables
i want to buy speakers cables for my home theater system. i am considering qed silver anniversary biwire. when i went to a shop, the seller recommended some DIYspeaker cables at cheaper price. he recommended solid core oxygen free copper type 4 speakers cables, and they will perform better than qed cables. which cables should i buy? and what is type 4 speakers cables? thanks
While I'll not argue the point on sounding better
Originally Posted by JBMAudio.com
I don't want to start up the great cable debate once again but I will say this. On my system I was able to hear a definate improvement in sound and my amp produced less heat when I switched to high quality Silver cables.
I also use pure silver (5n) cables in my system. I wouldn't have kept them if there wasn't a difference to me ears. But, your amp producing less heat is patently absurd. Are you trying to say that a .02 percent change in the cable resistance between a quality copper, and a pure silver cable caused your amp to "heat up"?! .
It's my experience that plated cables can be good.
It is my experience to stay away to from Plated cables. .
I use D.H. Labs SILVER SONIC silverplated OFC cable for my jumpers on my Magnepan 3.6r. The improvment was marked, and lasting.
That's funny, but he better get it vented
Yeah a buddy of mine uses that same amp, it produces some serious heat!!! But he doesn't help it out any, he has inclosed in a space that is just big enough to fit the amp :( I keep telling him to get some air movement going in there, but he doesn't care. I guess when his house goes up in smoke it will have all the air it needs :D
Even if he doesn't fry it right away, the heat will scorch the electronics and it will loose quality too. Stereophile just tested the new Krell 400ix and when it was smoking hot the THD was abysmal. (They almost fried the thing)!
