my first cable post
I recently started using my 5.1 analog out from a new bluray and only have the cheap rca iinterconnects so I need to upgrade LF,C RF channels. I currently have some audioquest and kimber pbj interconnects so kinda entry level but still quality interconnect.
any suggestions are appreciated also can you buy a single interconnect for the center channel
one last question I do have audioquest component 3 video cables will these work for audio also
thanks
I would think if you had enough the AQ & Kimber would be fine. Bluejeans makes a good budget cable that performs very well and you'd be able to buy an odd number of them. However, my entry Transparent RCA's were better than the BJC so I'd think the AQ & Kimber would be as well.
I'm really not sure about your video cable question.
How about "Yes" :)
