Ic Help
Has anyone used the acoustic research masters series audio interconnect? Does anyone know if it would be my best bet for a sub 50 dollar interconnect?
I don't know them...
however, under $50, check out Blue-jeans cable.
and A Qed Qunex2 might also go for something like that...
and Audioquest Alpha snake, G-snake or maybe the Sidewinder will also fit the budget, Audioquest will be the warmest sounding.
both are exellent products.
Keep them spinning,
Bert.
I own several pairs of AR IC's but not the Mater Series. The ones I own are well made with good rca plugs and good solder joints. I for the most part prefer solid core IC's and speaker cables. If you can stretch your budget you might want to check these out.
http://hcmaudio.com/comp.asp?compID=498
Is that the best value interconnect on hcm
