How to wire Dayton compression style banana plugs..
Hey all,
Here are the plugs in question:
http://www.partsexpress.com/pe/showd...number=091-330
Now, I know how to wire them if I were willing to run the wire in from the side...but..
Does anyone know how to wire these if I wish to run the wire from the 'bottom' up the hole in the hole in the center of the 'screw'?
I would think that I would bring the wire up the hole, and than over the compression plug and than screw it tight?
But the problem is that I simply can not fit my 12g wire past the compression plug..
Any ideas?
C
