Home made Cable ?
I want to make component cables for my HDTV.I was thinking using RG6 then putting a f to RCA adapter one them,then using color shrink tubing to help identify them.Is this ok for component cables,and digital?Also does anyone make a nice wrap that would cover all three component cables..???I have seen the split tubing from RS but looking for somthing that looks a little better and more flexible..Thanks ...
For a minute I thought you wanted to actually make up a coax:)
What you propose is just fine, not to worry:) Just make sure you put the same color shrink on the same cable :)
