Help with wire connection
While installing ceiling speakers during remodel my contactor connected the speaker wires to the terminals without noting which postive or negative terminal the stripped line wire or the non-stripped wire was attached to. Without going into the attic and pulling out the insulation is there any way to be sure I connect the right way on the amp?
Is there no visible difference between the two wires?
Usually one is one color and the other another or one has a stripe on it and the other doesn't, or one has a raised ridge and the other is smooth.
If so, just semake thet the same wire goes to the same connection on both ends. i.e, the white wire (or the ridge or the stripe) goes to the positive on both the amp and the speaker.
