Results 1 to 6 of 6
    Apr 2010
    Help out an amateur
    I was just wondering if there was an adapter that converts
    this - http://img18.imageshack.us/i/photoon20100424at1509.jpg/
    (that usually goes into this a socket thing like this - http://img704.imageshack.us/i/photoo...424at1510.jpg/)
    into this - http://img218.imageshack.us/i/photoo...424at1511.jpg/
    (that will go into this - http://img541.imageshack.us/i/photoo...24at15112.jpg/)
    At the moment i have just done a little wiring job but its a bit sketchy...... essentially what im doing is plugging in some decent speakers into a sub woofer (i think thats what its called) from a set of computer speakers i got and i was wondering if there was some kind of adapter
    thanks in advance
    Alex
    Apr 2010
    Looked through those can't find anything. Do you know the names of the wires/inputs im working with here? if so i could do i more comprehensive search...
    thanks
    jvc
    jvc is offline
    Still Learnin' jvc's Avatar
    Feb 2007
    Eastern NC
    Look through these pages and see if there's something to help.
    http://www.radioshack.com/search/ind...connector&sr=1
    Good luck!
    1080p Samsung HL61A750 LED DLP
    Onkyo TX-SR805 receiver
    Oppo BDP-83 blu ray player
    Polk Audio LSi9 front speakers
    Polk Audio LSiC center speaker
    Sony SS-MB100H rear speakers
    SVS PC12-NSD powered subwoofer
    Pioneer PL-514 turntable
    Logitech Harmony 628 Universal Remote
    So basically you want a mini rca plug ( 1/8" ) to a 1/4" plug
    http://www.radioshack.com/product/in...ductId=2109763. Your mini RCA plug will plug into the female end.
    This should work too, unless I am misunderstanding what you want. The mini RCA plug should plug into the female end of the plug below.
    http://www.monoprice.com/products/pr...seq=1&format=2
    Apr 2010
    Im probably havent been clear enough....
    The two wires are clamped into that red and black socket thing one wire in each and im try to get one of those clampy things that converts to a subwoofer input (which i think is 1/8)
    Thanks
