DVI vs Component Cable
Which should i go with? I have Digital cable with the HD channels and i was wondering is their a big difference in quality with buying a DVI cable? Thank you and Have a good and safe Holiday.
With a CRT television,go with component cables.You will get a better picture.When I had my HD installed i asked the installer,HDMi or component,he said go with compoment,I had to try both,he was right.
bill
Check out this web site and click on the link at the bottom left of the page discussing cables. www.bluejeancable.com its very informative, talks about HDMI and DVI.
