Quote Originally Posted by jneutron
While your components do not exceed the current draw, is the 300 volt plenum stuff capable of withstanding line transients in the 6 kV range, the flashover limit for outlets in the USA? That I would worry about.
Ok. What would be the criteria for said? Presumably the cheap UL listed 18 gauge lamp cord already meets that spec.
