coaxial digital cable lengths
at the moment i have a 1m length of kimber dv-75. I am looking to upgrade to the top of the line d60 cable. Only prob is that i can only get it in .5m length. the guy who i purchased the 1m off said that ide be better off sticking with 1m length because if i go with anything less i will likely end up having audio dropouts and problems like that. I find that a little hard to believe.
Anyone know if i would be totaly fine going with the .5m and there will be no difference,(maybe even a slight improvment over the 1m?) or will i end up having issues with it?
thanx:confused5:
