Cable recommendation for B&W speakers
I'm just wondernig what kind of cables people use on their B&W speakers, particularly the CDM, 700, or Nautilus series? I'm looking for a speaker cable pair to connect B&W CDM 9NT's with a rotel RB-1080 amp. I don't want to spend all that much though. I feel that Monster Cable/MIT cables are overpriced. Any suggestions?
How I wire my B & W Matrix 805's
First, the wire in question is Stinger 12 gauge, oxygen free. Yes, it's car audio stuff. Wire is wire, right, Mtry?? The amp ends are terminated with the screw-on pin connectors, which are a joy to use, and the speaker ends are stripped about four inches from the ends and span from the woofer terminals to the tweeter terminals. The jumpers were missing when I bought the speakers, you see. I feel no need for biwiring.
Laz
