Cable quetsion??
Printable View
  • 07-22-2009, 10:20 AM
    daniel.jenkins.93
    Cable quetsion??
    What is the name of the cable that connects the satellight speakers to the sub woofer. Also how long can these cables be?
    Please help?
  • 07-22-2009, 10:57 AM
    markw
    They are called "speaker cables" and they should be at least as long as the distance from the subwoofer to the satellite speakers.
  • 07-22-2009, 06:56 PM
    Mr Peabody
    Yeah, I'd say that's about right, any shorter and things could sound a bit boomy.
  • 07-22-2009, 08:11 PM
    02audionoob
    I would suggest that the length of these so-called speaker cables be longer than the distance between the sub and the satellites, in case you don't plan to connect them in a perfectly strainght line.
