What's the real difference between a composite VIDEO cable (or coaxial cable, if you prefer) and a conventional AUDIO cable? I can recall I read somewhere that video cables are 75 ohm, while audio cables are 50 ohm, is that correct?
Now another question, can I use a coaxial cable as a conventional audio cable? And as for the inverse, is it possible too? Please clarify...
Thanks for any info.
Demetrio.
