audible sound difference?
Would there be an audible improvement in sound if I replaced one of my speaker wires (16 gauge) that was cut and joined with a wire nut? It only goes about 20 feet and is used to connect my left front speaker. To replace it would be a bit of a pain but I now have plenty of wire. I thought I'd ask before I went to the trouble.
Thanks!
An unbroken connection is always best.
Thanks!
If it's not too much of a trouble I would replace the cut wire.
If that's the case I wouldn't sweat it.
Well, it's a little bit of a pain because it runs through a custom made speaker stand and then through a hole in the wall. I did it to the right speaker because I would have had to have 3 wires joined together because I moved my equipment into another room so you can't see it. Maybe I'll do it if I get bored- that's rare for me though:)
For me though, just the thought that if the wire get's pulled and causes a short would bother me too much. I've got a lot of $$$ tied up in my amps and I like them to stick around.
