Where can I find a 4-way crossover? Parts express only seems to have 2 or 3 way. I'm looking for tweeter/2X midbass/woofer configuration.
Thanks.
12-01-2004, 11:16 AM
kexodusc
Stop right there!
I seriously doubt you will find a 4-way, off-the-shelf stock crossover...and if you do, I'd bet that it's going to be absolutely worthless to you.
It's hard enough to match a stock 2-way crossover to your woofer and tweeter and get half decent results worth your effort, but a 4 way would be absolutely luck of the draw. Or you'd have some seriously out of synch speakers, I think.
Your best bet is to build one, and if you can't, or don't want to, seriously simplify your speaker project.
If you try hard enough, you should be able to find one of the boys on the PE forum to help you out.
