John-Mansville Spin-Glas Board
Has anyone looked at this material. It has the following sound absorbing coefficients for a 2" thick panel. 125 Hz - 0.38, 250 Hz - 0.93, 500 Hz -1.10, 1000 Hz - 1.07, 2000 Hz - 1.07, 4000 Hz - 1.07. I would like to find some others with whom I could purchase these. They are only a couple of bucks each (depending on size), but the minimum order is 100 pieces.
Here is the link with the information.
http://www.jm.com/insulation/perform...glas_board.pdf
I am having my wife quote this through a contractor friend of hers, but the dimensions are restricted to 48-72" by 92-96". I would like to buy these and cover with cloth (burlap?) if I can work out some way to do it.
