Tweeter diffraction control
I have found that IMO adding diffraction control around most dome tweeters helps with imaging. I have used foam weather stripping and now adhesive felt dots to break up early reflections. Sure it might take away from the look of the speaker but the sonic improvements are worth it. I was wondering how many others use some form of diffraction control and what you use? Thanks
It really depends on the needs and conditions
I don't lurk here much, but I happened to see your post. I agree that diffraction control helps imaging. The answer to your question depends on several factors, since there can be several sources of diffraction. These can be the driver faceplate (if not flush mounted), the cabinet edges (most commonly considered), obtrustions on the baffle (non-flat baffles such as steps) and adjacent drivers. All have an impact, but the magnitude varies widely.
There are also several means of diffraction reduction, as have been mentioned as well. Flush-mounting and offsetting the tweeter are two that should be considered necessities in most cases (aesthetics of offset notwithstanding). Roundover is effective, buy IME not as effective as a full real-wool felt application. Any "felt" that is not largely real-wool will be marginally effective, if at all.
My testing of even very large roundovers (I've tried 3") is helpful, but less effective than an optimal felt application. Roundovers are a good second, IMO, as far as edge treatments are concerned.
I have a couple of sections at my web site on the subject of diffraction control and the current issue of audioXpress has an article of mine specifically on the topic, all with information on where and what to buy that has shown excellent empirical results.
If you're interested, my site is:
www.speakerdesign.net
dlr
I have not links to any, but...
Originally Posted by poneal
I have a question for you. Do you know where there are frequency response plots of all the different types of crossovers. I've used 4th order LR xovers extensively, but I shy away from the others because I just don't know how they are supposed to look graphically. As you can probably tell, I'm pretty graphically oriented. That and very logical-->programmer. Appreciate your time, Paul.
I suggest that you go to the Liberty Instruments web site and download the free version of Praxis. I think that you can use that to generate the curves the interest you. You can also now save those files to disk.
If it doesn't have what you want, use the FRC spreadsheet at the FRD consortium. You can create target curves, or you can use the Passive Crossover Designer for targets as well. These latter ones required Excel, however.
dlr
