Just to give you some perspective...
I shopped for a new HT receiver last year and of those that I could confirm the DF on,(in my price range of $500-$600) the Yammi was the highest at 80. The others were down around 30-40. Mind you, it's not a common spec to put on the sheet, so there wasn't much info to go on for comparison. I had an old Carver "car" amp years ago and it had a DF of 100 and really did a good job with control. Most pro sound amps I found above the $250-$300 range were at least 100 as you've found yourself. Any would certainly be better than most of the plates offered today(for the money).IMO
If it were me, and if I remember correctly, the Mackie M800 would be a prime choice for my use on a sub. Another would be the Numark Dimension 3. Both were bridgable to somewhere around 600wts at 4ohm and both were in the $350-$450 range not to long ago. You may have to search and wait for a sale, but it does happen.
Here's some links I saved in my search's...
http://store.yahoo.com/efunctional/dimension-3.html
http://www.audiolines.com/ (goto audio menu, amplifiers)
http://www.musiciansfriend.com/srs7/.../search/c=4600
http://www.abemusic.com/samson/f1200.asp
Now, these were only the ones I saved due to either pricing, or info about the product. To find further info, you may have to search for the manuf. web sites as I don't have them myself to give. My only point here is to keep an open mind, do a little shopping before you make your decission, and BUY FOR THE FUTURE!!! There's times I regret not going with the prosound stuff to maybe gain performance(or maybe not) but the funds just weren't there at the time and I was on a schedule to get done before the wife left me for the mess I created!!! :D
Foot note...
Even if the rated power output is in excess of your needs, you can still turn the gain down on some amps or your source receiver/preamp and be safe.Ultimately, you will not use most of that power... most of the time unless you have the mains to back it up with.
You already know the answer to that my friend!
Sorry it took so long, doing acoustical tests on my soon to be new main 3-ways! A guy's gotta have priorities ya know!
The new amps from PE may be a good investment, I just don't know. Ask(e-mail) the guys at PE and see what they say about DF. Another web site that has more hi dollar plates is Adire.
http://www.adireaudio.com/diy_audio/...amplifiers.htm
The HS series look really nice... and expensive! The AVA 250 is probably the same as you and I have but alas, no DF spec on it. Maybe the guys at Adire know it. I never asked them.
Sorry man, of all the searching I did, I came to the conclusion the PE plate will have to do for now... until I get more motivated to do something about it.
