Wow, didn't figure it would draw that much attention and
I thank all of you. The drivers are the RS28, RS125, and RS225. This is a modular design as indicated in an above post. Also, it's hard to see but that little shiny metal clip on the door holds a battery which is connected to a reed switch so that when the door opens the bright LED comes on so that you can see the crossover parts and when you shut it, it breaks the connection and the LED goes off. I like to tinker around and the easy access of the crossover is definitely worth the extra effort it took to build. I must give RomanB some credit here because he came up with the box design and crossover. I just changed it up some to fit my fancy like the LED, easy crossover access, front firing port, and wheels. He has all the measurement data up on his page here: http://www.rjbaudio.com/Daedalus/daedalus.html. I tried to keep the dimensions as close as possible but ended up using some scrap 1/2" MDF for the sides of the mid/tweeter box. Again, thank you all. Paul.
MCH, not sure if you were aware of this or not but
if you hover your mouse pointer over the picture a little box pops up with arrows pointing out in the 4 different directions. If you click on this, the picture will expand to its original size which shows the detail better. Not sure if this is IE specific or not.
