replacement woofer suggestions...
I just picked up a pair of used JBL 2600. I stupidly didn't check under the grills since they seemed to sound fine. When I brought them home and looked under the grill, I foudn the woofer on both speakers was torn. When I hooked them up, and played something with some decent amount of bass, there was obviously a lot of distortion in the sound.
So, now I have to replace the woofers, but I don't know anything about such things. Can anyone suggest a decent 6.5" woofer? I've looked at Parts Express' site, but there are so many and I don't know how any of them compare to one another.
Also, a question about power handling... I've noticed that the drivers used in the speaker kits that are said to handle up to 150W RMS don't individually handle that much, so how is this number calculated?
