RCA interconnects
I got the plugs and the cable
How do I make it?
Inside the inner insulation past the shield there are red and black wires.
A little confused
How do I make it?
A little confused
Check this out...20A
http://rane.com/note110.html
ah
I see. Thanks.
Still not too sure why each conductor has red and black wires, but I guess they both go to the same place
I unscrewed the end of one of my Monster Cable RCA's(that I am not impressed with) and there are actually "3" leads. There is the positive and negative, inside the inner insulation. Then there is the shield wire that is braided around the inner insulation, which is then coated with the outer rubber/insulation. THe shield wire is not connected to anything. The red lead goes to the positive(center pin) and the black lead goes to the negative(outer housing).
Look at my home made interconnects thread. just an idea.
