Help w/ DIY Surround Speakers
I'm building a set of surround (5.1) speakers for a class I'm taking, but I'm on a tight budget ($500). I'd like to build a decent 5-speaker system for now, and add a subwoofer at a later time. I'm by no means an audiophile, but I do know what decent speakers sound like. Is $500 too tight a budget for this project? :confused:
Also, recommendations for speakers and plans are HIGHLY appreciated. I'm completely overwhelmed by the sheer amount of information out there, and haven't been able to find a good place to start. Thanks so much!
If you're into building from the ground up...
Check out the AR.com/Ed Fias DIY 2-ways here...
http://www.audioreview.com/Learncrx.aspx Lot's of good things said and have a pair myself. About $200us/pair for parts and you save $90 or so if you build your own box's. Lot's of support in this forum both current and Old AR forums(on right side of this page under "green links")
