Help identifying amp module
Hi
does anyone recognise this amplifier module? I found it in a Stadium PA amp someone handed in as part exchange, they'd obviously had a go at it themselves.
It would probably be of use as it would appear to be fairly high powered, but i can't find diagrams or any amps that use this end module.
I preume the shielded cable in is audio input, there's also two wires that are fairly obviously audio output, but which two voltages it needs are a mystery. I'll try 5 and 12 as a kill-or-cure, but it's not going to do it any good if i get it wrong.
The pcb is marked as Yamaha, but i haven't seen it in any yamaha amps.
if anyone recognises it please help me out.
Pic1
Pic2
Pic3
Pic4 (with annotation)
cheers, tom d
