Quote Originally Posted by Bigmoney
Would I be able to crossover both of my front speakers along with my sub. Is that what two way means? Two channels? One to mains and one to sub?
Correctly used, the term "2-way crossover" means a low-pass and high-pass filters combination.
The Behringer CS2310 is a 2-way but also has a mono subwoofer output; (however from what I can tell, the suboutput has only a low-pass filter, hence unless you want to use the mains full range, you have to use the stereo 2-way for high-pass).
The Behringer is a far more flexible than the Marchand in that it has variable crossover points. A slight drawback is that it has only balance outputs so you would need hybrid XLR-RCA cables; you can get these from, say, Markertek.
