Exhaust Fan for Denon AVR-3300
I want to add a fan to exhaust the heat out of the new wall-unit enclosure that my Denon AVR-3300 is now in. There are a couple of holes for cables in the back panel, and I have added a couple of more near the top section of the cabinet to help the heat excape, but I'd feel better if I had a fan pulling the heat directly off the top of the 3300 and out the back. That baby sure puts out the heat! I was thinking of using a 92mm or 120mm computer case fan for this, and maybe just mounting it on the back cabinet panel behind and above the 3300, but I'm not sure what I need to buy besides the fan which is lower voltage, or how to wire it up for power to get the correct voltage. I want it to go on and off whenever the 3300 goes on and off. I know others have done this for their Denon 3300, but I need some suggestions on what to do and how to do it. Thanks.
