I would recommend the ....
AR.Com from Madisound if there is no one locally who can build you some quality cabinets based on the specs. I've also heard good reviews about the PeeCreek DIY speaker. I believe they stopped making the original tweeter but there are replacements and they changed the names to More-Pee (using a Morel tweeter) and the U-Pee using the more expensive Usher tweeter. I have personally built two and in the process of making three more AR.Coms. They are an excellent choice in my opinion. I built my own cabinets and will post a picture in the next few days under the AR crossover DIY Forum thread. Ed Frias definitely had his sh*t together when he made these speakers. Just read the reviews about them here. Remember the DIY speakers should be done because you enjoy it (thats what its all about although the money does play in too). Good luck and ask any questions as Ed checks these boards regularly.
Here are the cabinet specs from Ed Frias...
AR.com Kit Cabinet specs:
3/4" MDF material
13" high x 8 3/4" wide x 9 1/4" deep
Port size is 2" Dia. (ID) x 6" deep from rear surface.
Rear Port hole is centered (widthwise) and 3" from top to center of port.
Speaker input terminal hole is 1 15/16" Dia. It is countersunk 3/16" deep x 3" Dia. This can be changed if you desire another type or size speaker terminal. Rear Speaker terminal hole is centered (widthwise) and 3" from bottom to center of hole.
Front Tweeter hole is 3 5/16" in diameter. Front tweeter hole is also centered widthwise and also 3" from top of cabinet to center of hole. If you opt to countersink the tweeter, cut 1/8" deep x 4 1/8" Dia.
Front woofer hole is 5 5/8" Dia. If you opt to countersink, use 3/16" deep x 6 15/16" Dia.
Front woofer is centered 4 1/4" from bottom of cabinet.
Success to all!
Ed Frias
EFE TECHNOLOGY Speakers
So I spoke with the great one and....
Thanks poneal and dave for all your imput and help. Ed actually chimed in and sent me an email regarding the madisound kit. I've been picking his brain and I got to tell you that guy is awesome...Thanks Ed!!!
