Results 1 to 10 of 10
Thread: vu meters
    2 channel lover
    Oct 2006
    mass
    Smile vu meters
    hey guys i have a set of wattage meters out of a dead no name amp. was wonderin the best way to hook them up to my reciever. to monitor the watts my speakers are pushing. any info would be greatly appreted!!! thanks
    I BELONG TO A REAL AUDIO
    FORUM
    Philadelphia, PA
    First of all speakers don't push watts. They use watts. Amplifiers "push" watts. Meters of that type are essentially useless. They are not accurate and there is really no way to calibrate them so they can give accurate readings.
    2 channel lover
    Oct 2006
    mass
    i kno that speakers dont push its just the way i typed it. so what would be the best way to check what my reciever is is pushin for wattage then?
    FORUM
    Nueva Jork
    Unfortunately...
    Quote Originally Posted by 2325fan
    ...the "...way i typed it..." is the way it came out, and I really, really want you to "kno" that...we can't provide correct answers to wrong questions.
    Best way? Probably math...and you'll need to "kno" a few incidental things like output voltage, etc...
    If you know the rated RMS output into the given load and your speakers are relatively efficient, and your average SPLs are say 80 dB or so, you can "ballpark" your normal cruising output at probably <5% of that value, generally speaking...Obviously, loud peaks will increase that number...
    jimHJJ(...BTW, VU meters don't measure Watts...it's Volume Units...relative to 0dB...)
    2 channel lover
    Oct 2006
    mass
    i kno that but im looking at the meters rite now an on the bottom it say watts @8 ohms so id say it measures watts
    FORUM
    Nope, RL is correct. The meter has been nominally calibrated for the donor amp's output running at a particular impedance to convert the voltage to display average power. Similarly, speedometers don't measure miles per hour. They count revolutions and convert the nominal diameter of the tire to display MPH. That's why changing the diamater of the tire affects the accuracy.
    Not really. It's somewhat tricky to wire meters.
    Try putting a 500 ohm resistor across the leads, and connecting it to a AA battery - many of these actually measure current. If you don't get anything, try the resistor in series with the leads.
    Keep trying with progressively until you get down to about 50 ohms - below this, the meter's probbably just dead.
    If you can find a value that gives you a swing that's all the way across the meter, you're set. Get a potentiometer roughly equal to the value of the resistor (a screw-turn trimpot is ideal), and turn it up to the maximum impeadance (the value of the resistor). Use an op-amp as a buffer on the input ( you don't need anything fancy here), and feed the output through a diode and the meter to ground. If the needle swings the wrong way, reverse the diode; you can adjust the sensitivity by adjusting the trimpot.
    This worked for me with a cheapie ammeter; it should work with some VU meters as well.
    2 channel lover
    Oct 2006
    mass
    sweet thanx it does work thanx for the info
    FORUM
