Complete Novice Needs Advice Re Fault Finding On Speakers
Can somebody explain to somebody who is about to attempt a speaker repair for the first time how to tell what is wrong with a mid-range driver in a 3-way speaker? What should I do to tell whether it's the actual speaker cone or the wiring or cross-over which is at fault please? I have looked all over the Internet for advice to no avail. Failing that can anyone recommend a beginner's easy to understand book which would take me through from the beginning. The fault by the way is a sort of fuzziness at higher volumes, I have swopped speaker cables around and it's still the same speaker so it's not my amp or cd player or anything. Thanks in anticipation. The speakers in question are vintage Celestion Ditton 66s, I know I will have to probably wait a long time to find the replacement part required but these speakers are so amazing I won't give up on them. Failing that can anyone recommend a speaker repair Docter in Berks or Oxon (United Kingdom) please.
