CD Player Lens Cleaning help
Hi,
Im using a NAD C541 cd player, and off late its starting giving a lot of error messages (ie while reading CDs) I think the cd players lens may need cleaning...
In the past i have opened up DVD Players n old LD Players for lens cleaning with a bit of scotch on a cue tip ... do u think its a good idea with the NAD or should i just send the unit to the shop for servicing? Only problem is that itll be out for 3 to 4 days!!
Any ideas?
Cheers,
Cayman
600 grit sandpaper and then 0000 steel wool
Just use 600 grit sandpaper then smooth it out with some steel wool. That always works for me! For all you Beavis and Buttheads out there don't take this seriously....
