I just thought that I would post a recent discovery that I made for a easy and inexpensive DIY for controlling the vibration of CD players or DVD players.
You know how you can go to just about any store and buy a halogen lamp? You know the ones that are tall with the upwards pointing light and sometimes they have a smaller lamp coming off the pole?
Well, if you either have one you are getting rid of, or you want to go buy one, the base of those lamps make for a great vibration control device. It's super heavy, usually black, circular, and is fairly inexpensive. Most lamps run about $20-$30, so that's pretty cheap in my opinion.
