• 05-07-2007, 05:07 AM
    leitmo
    build a technics sl1200 wood made
    hello to everyone!
    I'm thinking to buy a Technics sl1200MK2 turntable and change the metal chassis for a round wood made one, there will be no electronic changes, only the chassis but i have to be sure that the turntable is well damped with wood, any suggestion??
    Thank you!!!
  • 05-07-2007, 07:46 AM
    royphil345
    Welcome to Audio Review!!!
    It may not be so easy the way parts integrate on those things. The 1200 is not a plank with a few parts bolted on. It's the result of much evolution in turntables and the build is fairly complex for a simple manual turntable. If you want something like the 1200 in wood... Why not a Denon?
    http://brandnamez.com/merchant.ihtml...ffNo=522045544
    http://www.needledoctor.com/Denon-DP...&category=1110
    Not saying it can't be done... but look... http://www.fileden.com/files/2007/4/...ded%20view.JPG The 3 different sections / materials of the stock chassis, along with the very nice feet do a pretty good job of controlling resonance...
    Alternatively, you could buy something like this... http://cgi.ebay.com/technics-sp-25-t...QQcmdZViewItem Add a tonearm... armboard... Build whatever kind of plinth you want. Just build it solid, damp it with damping sheets if you see fit, install nice feet... Much easier... Probably better performance...
