Belt replacement in Rotel RCD 1070 CD player
No, it's not a belt-drive CDP, it's the belt that opens and closes the disc tray and also drops the laser carriage out of the way.
After years of tapping the damn door with my knuckle to get the thing to take a disc, I finally opened it up yesterday and found it just needs to have the little belt that drives the door replaced, it's stretched out. I cleaned the belt w/ alcohol and its working fine for now.
I can do this job myself if I can remove the drawer. I can disengage the drawer from the drive gears, but so far I cannot see what I need to do to get it to slide right out and off the unit.
Does anyone reading this have experience changing the belt on an RCD 1070 (likely the same as a 1072, no?)
Thanks in advance
--brett
