AR.com Kit Cabinet specs:
3/4" MDF material
Outside dimensions are
13" high x 8 3/4" wide x 9 1/4" deep
Inside dimensions are
11 ½” high x 7 1/4” wide x 7 ¾ deep
Port size is 2" Dia. (ID) x 6" deep from rear surface.
Rear Port hole is centered (widthwise) and 3" from top to center of port.
Speaker input terminal hole is 1 15/16" Dia. It is countersunk 3/16" deep x 3" Dia. This can be changed if you desire another type or size speaker terminal. Rear Speaker terminal hole is centered (widthwise) and 3" from bottom to center of hole.
Front Tweeter hole is 3 5/16" in diameter. Front tweeter hole is also centered widthwise and also 3" from top of cabinet to center of hole. If you opt to countersink the tweeter, cut 1/8" deep x 4 1/8" Dia.
Front woofer hole is 5 5/8" Dia. If you opt to countersink, use 3/16" deep x 6 15/16" Dia.
Front woofer is centered 4 1/4" from bottom of cabinet.
Success to all!
Ed Frias
EFE TECHNOLOGY Speakers
