Results 1 to 5 of 5
    frenchmon frenchmon's Avatar
    St. Charles Mo
    Wired 4 Sound amps.
    Been looking at the mono block amps at Wired 4 Sound for a while now. Interested in the W4S SX-500 Monoblocks. Unbelievable power at 250 watts per mono....
    Does any body have any experience with Wired 4 sound products?
    Thanks
    Springfield, Mo
    I have read posts on forums explaining how thloey compare to the class d audio amps like mine and it is always a toss up on which sounds better but it seems the Class d audio amps seem to usually win the sound offs I have read. I don't know the price of their Mono blocks but you could have a pair of mono blocks built by Class d audio for less and they would probably be better or at least as good. But I will say this if the W4Sound amps are being compared to the Class d audio amps then they are quite good in my opinion since I have been blown away with my amp.
    Marantz SR5008(HT)
    Pass Labs X150.5(2 channel)
    Yamaha NS-c444 center channel
    Samsung 46" LED TV
    PS Audio Quintet power center
    St. Charles Mo
    Quote Originally Posted by harley .guy07 View Post
    Hi harley...where you been?
    Hey what is the characteristics of the class D amps?
    Characteristics of class D amps? Well for starters they differ from each other just like other basic amp types.
    However to generalize, (from all I've heard), class D, more properly a.k.a. "switching amps":
    = Have high output impedance so have high damping factors and are tolerant of speaker load.
    = Offer high power especially relative to their size, weight, and power consumption; (they're "green").
    = If a class D comes with "switching power supply" (SMPS), a class D is even lighter than if it come a linear supply. However lots of people seem to prefer the linear supplies for supposedly better sound.
    = Given high damping factor, class D's tend to have very controlled bass -- whether this is totally good depends on the speaker being driven.
    = Class D's are often described as very transparent and detailed-- this has been my personal (though limited) experience. This despite that class D's supposed can have a lot of ultrasonic noise and can't reproduce a square wave. (Ask yourself, do I listen to square waves?)
    = Class D's, (coincidentally like other solid states), don't have the "warmth" and/or "harmonic richness", or sense of ambient depth that (many) tube amps do. (Personally I believe the tube attributes are actually artefacts, but hey, everybody has their own opinion.)
    = Some class D amps are built using off-the-shelf modules from notable makers such as ICEpower or Hypex; others use these modules with proprietary capacitor or front-end "improvements" and/or improved power suppliers. Others are proprietary designs based on logic chips from Texas Instruments, International Rectifier, or Tripath. (Tripath is out of business but there is still a huge supply of their chips on the market).
    An example of amp using a highly modified OEM-based design is the new Rogue Medusa and Hydra hybrid tube/class D amps, HERE. According to Mark O'Brien as reported HERE, the amps use Hypex modules but with their front-ends bypass in favor of an in-house tube driver stage. They use linear power supplies too.
    Springfield, Mo
    Feanor pretty much nailed it on what the class d amps are like compared to other designs. To me they seem to have more detail than most other ss amps I have heard without the edgyness the comes with other ss amps. In fact I have not heard an amp yet that has sounded this good on my speakers. While tubes do have a certain characteristic that some find attractive I agree with Feanor that this may not be the more natural sound of the music but a trait of the tube designs themselves.
    Marantz SR5008(HT)
    Samsung 46" LED TV
