Question on ac power supply for power amp
Hi,
I have recently purchased a Rotel 1075 (125w X 5 channels) used to as a power amp connected to my NAD 760 acting as the pre-amp. The 760 does not have a 12v switch to turn trigger on / off the power amp. I was wondering if it is okay to used the swichted power outlet on the 760 to connect the power amp. Or does the Rotel have to go directly into the power strip? I want to turn off the amp when not in use, but want to make sure the NAD 760 can supply sufficent power for the amp.
Thanks.
Hareesh
