• 07-15-2005, 08:41 AM
    FlyingV
    Problem with low sound signal
    Hi all,
    I have a problem with my stereo sound system that I was hoping some of you might help me with. I have a Denon DRA-375RD receiver that suddenly stopped functioning properly. The sound signal from the speakers is really low; if I turn the volume to max, the sound is barely audible. The same thing happens when I use headphones, meaning that the problem is not with the speakers or speaker cables (?) Also, there is no difference between using a connected Cd-player and the radio, and I have tried different outputs (tape, phono, video,cd-player). This means that the problem is in the receiver itself somewhere, doesn't it? The power supply maybe? Or with something else? Any tips?
  • 07-15-2005, 09:07 AM
    Glen B
    Originally Posted by FlyingV
    Hi all,
    Before you start thinking the worst, check the MUTE function. It could have been turned on accidentally and you don't realize that its on.
  • 07-15-2005, 11:21 AM
    mixadude
    Or perhaps a tape monitor circuit is engaged?
