Mono block V.S. power amp, What the big difference?
Why do people use a mono block amplifier compared to a typical stereo power amp. I know the power amps are usually stereo and handle a pair of speakers or more...
Why not just get 2 mono block amplifiers and use them as your power amps? Any reason someone cant do this?
What are some of the advantages/disadvantages of this configuration?
There are many excellent examples of each.
A lot of it boils down to economics. Ever look at the prices of hefty power transformers and caps?
Unless you're talking really, really high power, it can be much more economical to design one very good power supply for two channels on one chassis than to apply the same to two separate chassis.
As for signal separation or crosstalk, that's one of those "can I really hear the difference?" situations. Unless you're coming from two separate preamplifier, it's pretty much a moot point.
but, it does look kewl and impresses the heck out of the unknowing.
