MARANTZ 2220B need help with lights:
i have a marantz 2220B and it works fine except the blue illuminated lights on the tuner dial dont work and i think another one that is run on the same fuse as the tuner ligthts dont work either the pointer light works. i am wondering if i need to take it apart and i need to know if there is fuses on the inside of the amp behind the tuner dial internally?
can someone tell me if i need to open this thing up and change internal fuses for the illuminated lights to work again?
thanks
schneidey
