Help - Problems with my Sherwood AX-4050R Amp
Hi everyone.
I need some advice regarding my Sherwood AX-4050R Amplifier.
To be fair, it is a few years old now, and has served me very well, but recently it has been unable to play at anything other than extremely quiet. Whenever I play a CD, unless the volume is very low, the amp simply cuts out, and returns itself to standby. You can hear it clicking off.
I run a Cambridge Audio D300 SE CD deck through it, and have had a TV running through the AUX channel via a 3.5mm - Phono cable from time to time. The speakers are Gale gold monitors.
I had noticed this problem occurring before, but only when the top of the amp had been covered, but at the moment it is on the top of the stack (and not covered by anything), and by a window that is open - so I cant see that overheating is a problem.
I have taken the cover off and blown all the dust out with some compressed air, and I have also changed the speaker cables (just in case!) but to no avail. The problem is the same whether I run the CD player through the CD channel or any other channel.
Oh, I also tried running the sound out through both the A and B speaker circuits, but with the same problem!
Is the amp dead, or is there something else that I am missing or can do to sort the problem out??
Thanks in advance for any help or advice that you can give me!!
Ed
